Roaming in Costa Rica - how well does Koodo roam in Costa Rica?
  • Jun 4, 2025 8:19 PM UTC
  • 335 views
I can’t add an eSIM (old Iphone X) so I am hoping to use Koodo Easy Roam, Roaming until I get into a store to buy a local SIM. Has anyone used Koodo Roaming in CR and were you able to get a Network - at least in major cities like San Jose ?
Best answer by Flo Koodo
Hi ​@MelanieAM
Koodo’s roaming partners have usually good coverage in the most important areas, however for exact coverage, we recommend checking the available roaming providers in Costa Rica here https://assets.ctfassets.net/8cecwr1x4jkf/4LXFhimjwcok4pWRX7opfh/ec82c8c4d2d6347da76181f40e05c037/English_Coverage_Maps_Updated_2022_09_30.pdf and check then their coverage maps.
  • Jun 4, 2025 8:38 PM UTC
Hi ​@MelanieAM
  • Jun 4, 2025 8:42 PM UTC
For a cheaper rate, I would suggest you to sign up for the 7-day USA Easy Roam Travel Pass before you go abroad. https://www.koodomobile.com/en/help/europe-easy-roam-travel-passes
  • Jun 4, 2025 8:50 PM UTC
Thanks for the suggestion. I don’t think the Travel Pass works in Central America ? But please let me know if I am mistaken.
  • Jun 4, 2025 8:56 PM UTC
It should work in Puerto Rico as an eligible U.S. destination. There are also some eligible Caribbean destinations, which you can get with the 7-day Caribbean/Mexico Easy Roam Travel Pass.
  • Jun 5, 2025 11:53 PM UTC
You are correct.  No Koodo Travel pass covers Costa Rica
