I am travelling in Mexico… have the airplane mode on, using my wifi at home, celular data off, roming data off and I keep getting text from Koodo that roaming started runjing for my ohone number and I will be charged unless I have a plan or pass. This is everyvtume I travel and I am gettingvtired of this. Customer service is impossible to contact. Help plase!
Roaming
Best answer by Dinh
That text is the generic roaming welcome notification, it doesn't mean you're actually being charged. Incoming texts never trigger a fee as long as data and data roaming are off and you don't make or answer calls or send outgoing texts. https://www.koodomobile.com/en/help/understanding-how-youll-be-charged-while-travelling
Have you checked your usage in self serve? any actual Easy Roam charge would show up there. If one does show up, there's a bill review tool in self serve you can use to dispute it.
Login to the community
or
