Removing: Pay-Per-Use Intl Long Distance
  • Nov 29, 2022 10:39 PM UTC
  • 1 reply
  • 219 views
What happens if I remove add-on: Pay-Per-Use Intl Long Distance ?
Does that simply stop/block outgoing long distance calls from happening?
1 reply
  • Nov 30, 2022 12:05 AM UTC
It would only block outgoing calls to international number except numbers starting with the country code +1
So, technically without the addon you can still call US numbers.
