Removing device care “Add on”
  • May 20, 2023 10:13 PM UTC
  • 286 views
I tried removing device care from add-on in self serve, i tick the i understand button and confirm changes but it goes back to the I understand check box. I use incognito and clear cache but still same thing happens. The shop said i can easily remove it via self serve but this happened.
Best answer by Boa_Guy Koodo
Hi there @Boboraro  We have submitted the request for the Device Care Complete to be removed from your line as requested.
Cheers,
  • May 20, 2023 11:00 PM UTC
Howling have you had the device care complete on your line? I wonder if your account was new and there was some restriction to remove it in selfserve
  • May 20, 2023 11:11 PM UTC
It did add  the device care recently but I was told I could remove it from my account whenever I chose.
  • May 20, 2023 11:25 PM UTC
Let me flag a rep to look into it.
  • May 21, 2023 1:16 PM UTC
Hi @Boboraro
We can submit a request for the Device Care Complete to be removed from your line. Once removed, it cannot be added back. Please let us know if you wish to continue. Thanks!
  • May 29, 2023 3:11 AM UTC
Yes please @Flo Koodo.
I’d like it removed.
Boa_Guy Koodo
  • Koodo Alumni
  • May 29, 2023 1:06 PM UTC
Cheers,
