Remove Long Distance Calls
  • Nov 4, 2025 2:59 AM UTC
  • 1 reply
  • 137 views
MoFromTo2018
Anyone know how to remove the ability to make long distance calls?
Someone random caller, called me from US; I don’t even have a recollection of calling them back, but now I have a charge of $0.80.
I want to remove the ability to make calls outside of Canada. How can I do that? I tried removing the add-on myself, but I am unable to. If it helps, I use an iPhone 14 Pro, on iOS 26.0.1.
Your help will be greatly appreciated.
Best answer by Dinh
As a postpaid customer, you're unable to restrict outbound calls to U.S. numbers. Koodo does not currently offer the option to block the +1 country code.
You can ask a rep to remove the Pay-per-use international calling add-on, but keep in mind that doesn’t block calls to the US.
1 reply
  • Nov 4, 2025 4:03 AM UTC
