please fix plan
  • May 23, 2026
  • 7 replies
  • 89 views
Switched from public mobile to koodo yesterday for attached offer but checkout didn't complete and agent applied wrong plan to my account . Please fix to attached 29$ plan. Getting run around probably already around 4 to 5 hours of 'support' in
Best answer by WillH
Chatting with expert on Koodo Assist Messaging got this sorted 🙂
PS thanks for the responses
  • May 23, 2026
Hey, this is customer forum, we didn’t have access to the latest promotion from Public mobile. Can you share more the detail about your case? all I saw as of now are screenshot of 2 different plans. Which plan are you on?
  • Rockstar
  • May 23, 2026
Hi Dinh  im supposed to be on the $29 plan on the left with koodo, I was previously on the $29 plan on the right with public mobile (yesterday). Either plan would be acceptable. However the 65$ plan the agent applied to my account is not acceptable
  • May 23, 2026
@WillH
We see that you discussed with the Expert Messaging team in the meantime and a call back has been scheduled.
Please let us know if you have further questions or if you need further assistance.
  • Rockstar
  • May 23, 2026
The scheduled call back time has past and I did not receive a call. What number should I call?
  • May 23, 2026
They should have called three times. If you still do not receive anything within an hour or two, you will likely need to schedule another callback through Koodo Assist. https://Koo.do/Chat
  • May 24, 2026
When you request a callback there should be a text that says the call is coming. Did you get that?
Did you also check to make sure koodo's number is not blocked?
  • Rockstar
  • May 24, 2026
