Phone charges while using travel pass
  • Oct 19, 2025 7:57 PM UTC
  • 2 replies
  • 225 views
Hello, during my recent trip I used a 30 day Europe pass and assumed that this covered me for the EU countries listed. I made a call between EU countries and was charged long distance rates. It does not say anywhere in the Travel Pass or Roam like Home pages that intra-Europe calls are not included, and the text I received when I entered the country implied that calls to other countries were included. Could you please review the charges or point me to the FAQ that would have stated this? This is one of the pages I reviewed: https://www.koodomobile.com/en/help/easy-roam
And the text I received said "REMINDER. To make calls to Austria (Country Code = 43) and other countries, dial "+" followed by "Country Code" and the number (e.g., +43-XXXXX-XXXXX)."
Since I purchased the EU plan, I assumed this meant I could call another included country. Thanks for your time!
Best answer by Dinh
The Easy Roam package doesn’t include intra-calls between foreign EU countries. Since it’s not stated or confirmed otherwise, charges would apply unfortunately
The SMS you received provided instruction for making international calls. It did not indicate that those calls are free with easyroam
  • Oct 19, 2025 8:10 PM UTC
  • Oct 19, 2025 11:30 PM UTC
I believe the way it works is that you are covered for calls within the country you’re in, and if you og to another country in the Europe list, you’ll also be covered for calls in that country you have moved to.
I did try going through the FAQ for easy roam travel passes, and unfortunately don’t see anything explaining that:
https://www.koodomobile.com/en/help/europe-easy-roam-travel-passes
This forum post here confirms it:
I do, however, think it should be more explicit in the seciton on travel passes.
