Perks don’t seems to work
  • July 22, 2026
  • 4 replies
  • 65 views
Hi,
I’m supposed to have the 10Gb data bonus for my perk but it don’t seems to work and my account says that I no longer have data available but the cap is only 1Gb. Is that normal?
thanks
Best answer by Flo Koodo
Hi ​@Xychus
We have looked into it and we found that the perk wasn’t prvovisioned correctly.
We have managed to fix it and you should be able to see it in self serve and in the usage section.
You might need to restart your device if data is not working,
Please let us know.
  • July 22, 2026
To confirm, did you recently change to a new plan / sign up for Koodo? As when you change your plan / activate a new line, you will have access to a prorated amount of data until your next billing cycle. This would explain why your data amount is 1GB and not what is expected with the plan, it will be like this until your current billing cycle is finished. If that is the case, more on that can be found here: Rate plan proration explained | Koodo Mobile
For the perk, when you check your add-ons in self-serve does it show that the perk has been selected? If you did change your plan, did you choose this perk at the same time or a different perk at the time of the change and then switched it later?
  • July 22, 2026
I did not change my plan recently. Although I tried to see if it was activated. The option was selected on day one when I choose my plans months ago.
  • July 22, 2026
Hi ​@Xychus
Please let us know.
  • July 22, 2026
Everything seems fine now!
Thanks!
