Perk Not Showing
  • April 10, 2026
  • 19 replies
  • 131 views
Hi everyone,
I just recently joined Koodo and ran into a perk issue. When I selected “Unlimited long distance,” I received a message saying “Your plan has been updated,” but I never got a confirmation email. Also, the perk does not show as selected in my account.
I’ve tried going through the change‑perk process and selecting a different free perk, then went back and re‑selected my original option. However, it still isn’t working.
Has anyone else experienced this? Any ideas on how to get it fixed? Thanks!
Best answer by Dennis
Let me flag a rep for you. Please make sure you are logged in to your self serve account
  • April 10, 2026
  • April 10, 2026
Hello ​@Alliswell ,
We have reviewed the account and tried adding the perk from our end and encountered the same error as you. We will send a form to request the perk to be added.
  • Organizer
  • April 14, 2026
Hi, I’m still not able to resolve this issue. The perk has not been added to my account, and I also didn’t receive the form that was mentioned. Could you please confirm the status of this request and resend the form if needed?
  • April 14, 2026
The form is submitted by the rep to the Perk team.
It typically takes a few business days.  I would give it until Friday.  Report back if you see no changes by Friday
  • Organizer
  • April 16, 2026
Hi, I’ve noticed that the perk has now been added to my account—thank you for resolving that. However, we made a few calls earlier under the impression that the perk was already active. Would it be possible to have those call charges reviewed or removed since the issue appears to have been caused by a system error on Koodo’s side?
Hi ​@Alliswell, glad to hear the perk was successfully added. Once the bill showing the charges has been issued, please let us know here and we can look into charges then.
  • April 20, 2026
Hi Koodo, I have the same problem - with the Internal Easy Roam perk. Added it in self-serve, never got the confirmation email, and the perk doesn't show enabled in self-service. In fact, it still asks me to select my free perk. I tried several times 2 weeks ago, and now again.
@Koodo could you fix this for me manually as well, please?
  • April 20, 2026
Hi ​@DrIPhone
Can you try adding a different perk and see if the system lets you? If it does, you should then be able to switch to the perk that you would like. Some others have found this to work.
If it doesn’t work, let me know and I can flag a rep back to the post to see if they can add the perk.
  • April 20, 2026
@DrIPhone
Just to double check, are you looking to add the 3-day Easy Roam US or International as the free perk?
  • April 20, 2026
Hi ​@Oliver C  - I tried adding the long-distance perk - didn’t work either.
@Flo Koodo - yes, 3-day Easy Roam International, please.
  • April 20, 2026
Thank you for confirming ​@DrIPhone
We have tried to add it from our end but we were unable to.
We have submitted a request and it will be added in the backend within 3 business days.
We are sorry for the inconvenience created!
  • April 24, 2026
Hi Flo, thanks - the perk shows now as activated.
  • Organizer
  • April 24, 2026
Hi ​ ​@Georgia Koodo , the bill has now been issued and shows $19.80 in long distance charges for calls made before the perk was added (due to the system error). Can the team please review and credit these charges? Thanks!
  • April 24, 2026
Let me flag a rep for you ​@Alliswell
  • Organizer
  • April 24, 2026
@Dennis Thanks!
  • April 24, 2026
Hi ​@Alliswell, I was able to credit the long distance charge, the bill will not be re-issued but you can see the updated total due in your self serve.
  • Organizer
  • April 24, 2026
Thanks! ​@Koodo  I see the updated total due. I've set up pre-authorized pay, so it should only take the total due amount, not the original bill, right?
  • April 24, 2026
Correct
  • Organizer
  • April 24, 2026
Thanks ​@Dennis
