Outgoing texting charges to number using Easy Roam
  • Apr 30, 2022 2:09 PM UTC
  • 4 replies
  • 205 views
If my children in Canada using Koodo text me while I’m in the States using Easy Roam will they be charged for texting to the U.S.? I think they have a very old plan.
Best answer by Goran
No they won't. They're texting a caandian number and that's all that matters. Even on Koodo’s original plans.
  • Apr 30, 2022 2:11 PM UTC
Sophia
  • Apr 30, 2022 4:04 PM UTC
You however will have roaming costs if you text back (either with Easy Roam or without). Depening on how long you’ll be in the US, you could consider a local SIM card and then use a service like WhatsApp, Telegram or Signal to text with your children. That will work across any service or country without needing to use the Koodo line.
  • Apr 30, 2022 6:38 PM UTC
I have used Easy Roam before and have never incurred roaming charges for texting to Canada.
Sophia
  • Apr 30, 2022 6:52 PM UTC
Right, if you use Easy Roam, you can text Canada and not pay any further fees - I didn't word it very well 🙂
