Missing Plan Options
  • Sep 6, 2022 12:24 AM UTC
  • 1 reply
  • 91 views
My wife and I are on the exact same plan and have been for a couple years.  I have a lot of plan options to put my wife on, but only 1 $60/m option for all tabs for myself.  What’s going on here?  I tried a callback option but the call just goes to voicemail every time without ringing, so I can’t answer it.
1 reply
  • Sep 6, 2022 5:34 AM UTC
I suggest you check block list in the phone and see if you accidentally blocked Koodo call back number (so it went directly to the voicemail)
i suggest you contact via Facebook/Twitter messaging. Links are the bottom of this forum page
