Koodo vs Telus at same price and data?
  • August 24, 2026
  • 2 replies
  • 102 views
I was about to switch my PM $35 100GB Can/US/Mex plan to an offered Koodo postpaid $40 150GB Can/US/Mex plan to get access to roaming for an upcoming trip.  I hate to pay the extra $60/year since the extra data isn’t needed, but roaming my existing number rather than a temporary country data/# SIM is highly preferable in my case.
I notice I’m also being offered a Telus $40 plan, 100GB Can/US.  Mexico is no loss, and 100GB is an order of magnitude more than I’ve ever hit on data use, so the 150GB with Koodo isn’t a huge loss.  Would there be other advantages to going with Telus?  It seems unclear if Koodo is limiting 5G at 1GB (the offer banner) or 260MB (the fine print, perhaps out of date).  In theory I might have access to faster speeds with the Telus plan, although I spend half the in cottage country which has no 5G at all and don’t desperately need huge bandwidth even when in the city.  Do Telus speeds tend to actually be significantly  faster in the real world?  I’m not a multi-service or household candidate for Telus.
None of the Koodo perks are especially compelling - I’d never need rollover date with 150GB/month.  It is a pity these upgrades are by design only offered with increased rates; I suspect there is a $35 switch plan they are showing to lower end PM customers.
Sophia
  • August 24, 2026
I’d say there is no real advantage of Telus over Koodo. Both offer very high speeds now and Koodo has the same level of service. If you have Telus Internet, you’d get your $10 discount all the same.
Unless you have a personal preference for Telus, I would probably pick the Koodo plan.
  • August 25, 2026
Telus does offer higher data speeds up to 2 Gbps. However, you may not be able to take full advantage of it unless you are located in an urban centre. The speeds will remain the same in cottage country, as both carriers are using the same towers.
All things considered, Koodo seems to be the better choice, since the plan provides more data and includes roaming to Mexico.
You may also be able to choose the 3-day Easy Roam International Perk, which may come in handy for those trips outside of the U.S. and Mexico. https://www.koodomobile.com/en/services/pickyourperk
