koodo ignored my $60 European roaming add on continued
  • July 2, 2026
  • 3 replies
  • 50 views
Last month I contacted koodo about this problem with my European roaming plan from May and Junw not followed and koodo replied that they would remove $60 for May and after June to reconnect. June had European roaming charges as well and shouldn't.   Please fix these over charges.  Thank you.
  • July 2, 2026
Let me flag a rep to look into it. It appeared the issues has been identified but Koodo would like to wait for the bill to be generated to resolve it for you.
  • July 2, 2026
Did you try to submit a request for a rep to review the charge on your bill? You should be able to do it on your Self-Serve account. https://www.koodomobile.com/en/help/ask-us-to-review-a-charge-on-your-bill
Rox Koodo
  • Guardian
  • July 2, 2026
Hi there, ​@Mklip !
Thanks for flagging this to us. I have successfully credited the charges to your account. It will pay you on your upcoming bill.
We’ll be here in case you will have other questions.
