International long distance saver ad on
  • Jun 3, 2023 5:22 PM UTC
  • 203 views
How can i remove subscription to the international long distance saver add-on?
Best answer by Flo Koodo
Hi @F_Amoah
We have removed the add on for you, feel free to check the details in Self serve.
You will see a partial adjustment on the next bill.
Have you tried to remove it on a different browser,  laptop/computer?
Mayumi
  • Jun 3, 2023 5:53 PM UTC
When you login to self serve and go to mobile service > manage add-on, do you see the add-on there?
And what happens when you click remove it?
  • Jun 3, 2023 6:45 PM UTC
It does not give the option to remove
  • Jun 3, 2023 6:49 PM UTC
Let me flag a rep to help you out.
  • Jun 3, 2023 6:51 PM UTC
ok.. thanks
  • Jun 3, 2023 8:33 PM UTC
Hi @F_Amoah
  • Jun 3, 2023 8:37 PM UTC
Thank you… its been removed
