incoming international texts SMS
  • Apr 19, 2022 9:42 PM UTC
  • 8 replies
  • 803 views
I am not receiving incoming texts while in Mexico. They are no charge I understand. Do I need Easy Roam activated to receive any incoming text messages?
Mikey in Poco
Best answer by Boa_Guy Koodo
Hi there @MikeyinPoco !
We have added the Easy Roam options to your account.  You should now be able to use your device abroad. Please restart your device and everything should be working.
Here is more info on Easy-Roam: https://www.koodomobile.com/en/help/easy-roam?search_api_views_article_search_fulltext=easy%20roam
Edit: It is recommended to turn DATA and data roaming off in roaming or switch the phone to airplane mode to avoid unwanted charges.
Bernard Koodo
@MikeyinPoco Looks like you activated with us online a little over a month ago.  During the online purchase process we always recommend Easy Roam as you only pay for it if and when you use it. Did you opt out of Easy Roam? Indeed you will need either Easy Roam or international data and voice access by themselves.  This page here will guide you what maybe the best option for you and your current situation:
https://www.koodomobile.com/easyroam#
  • Organizer
  • Apr 20, 2022 1:35 PM UTC
I get to Self serve/ Manage Services/Easy Roam but no Add button to enable it. Also cannot text ROAM to 7626.
Mikey in Poco
  • Apr 20, 2022 1:49 PM UTC
How to add Easy Roam to your account
Only Authorized users are able to add Easy Roam to an account.
Log in to your Self Serve account.
From the Self Serve dropdown menu, select Mobile services
On the Mobile services page, select "Travel with Easy Roam"
On the Easy Roam page, select the "Add to plan" button
You're good to go! You can now use your Koodo phone while travelling abroad.
  • Organizer
  • Apr 20, 2022 2:51 PM UTC
I do not see an Add to Plan  button on the Easy R
oam page. Am I an authorized user or what is an authorized user ?
MikeyinPoco
  • Apr 20, 2022 3:23 PM UTC
MikeyinPoco
An authorized user would be the account owner or a person on the account that has been assigned as an authorized user by the account owner.
Does it show as active in that page?
When I go to that page I see this, but my easy roam is already active.
  • Organizer
  • Apr 20, 2022 7:14 PM UTC
Hello Dennis,
Do not see that screen that you see,however you are active. All I need is to activate Easy Roam but no "add to plan" button under Manage Services/Easy Roam.
Mikey in Poco
Boa_Guy Koodo
  • Koodo Alumni
  • Apr 20, 2022 7:18 PM UTC
Timo Tuokkola
Personally, I'd suggest turning off data entirely, as just turning off data roaming occasionally allows a small amount of data leakage which has sometimes been known to trigger easy roam charges.
