I want to switch my plan without paying $50
  • August 29, 2023
  • 10 replies
  • 446 views
I’m just looking to change my plan without paying the $50 charge. I’ve been on calls with 3 different agents and I’m still under the same plan.
  • August 29, 2023
If you are calling agents to make the switch you will be charged.
If you sign into your account and make the change yourself, you will not be charged.
Timo Tuokkola
  • August 29, 2023
Even if an agent changes the plan for you, the fee is $15, not $50.
Bernard Koodo
  • August 29, 2023
@morningowl22 It looks like a lot of the extra charges are for data top ups. You have access to a special plan online that would give you more than 3 times the data you have in your plan today (12gb) and pay the same amount as your current plan ($50). There is no fee for switching plans online. I hope this helps.
  • August 29, 2023
I try to switch it online and it tells me there’s a problem on my account and to call an agent. I’ve wasted so much time. Spoke to 3 different agents that had no idea what was going on. Trust me i wish it was that easy. I never wanted to purchase data top ups but this system is the most difficult and frustrating.
  • August 29, 2023
It says there’s a problem on my account and prompts me to call an agent.
  • August 29, 2023
I’ve spoken to 3 different agents and each of them said $50.
Bernard Koodo
  • August 29, 2023
@morningowl22 Once payment is made everything should work.
  • August 29, 2023
I’ve been trying to do this for months. If the plan was changed over I would never have to spend outlandish money on data top offs. Last agent I spoke with should of changed my plan. Look at my call logs with Koodo agents and see how much time I’ve wasted. If I have to pay for these data top off’s it will be my last payment with Koodo. Like you pointed out, I can be paying $10 more for 48GBs more of data.
  • August 29, 2023
Ok you never said that.
Timo Tuokkola
  • August 29, 2023
