I have an offer to switch to a cheaper plan but what happens to my add-ons?
  • Nov 21, 2021 3:08 PM UTC
  • 710 views
Hi there - I have a chance on my account to change to a cheaper plan.  My question is what happens to my add-ons if I switch plans?  It doesn't say anything about that.
Best answer by Bernard Koodo
@vtecman If you change plans the 1,000 min add--on will stay on your account for now.  That may change in the future but for now you should be fine.
Allan M
  • Nov 21, 2021 3:24 PM UTC
Add-ons are a tricky one.
Which add-ons are you referring to? A good chunk of $0 data add-ons will drop when you switch plans if these are ones you're talking about.
  • Advocate
  • Nov 21, 2021 3:25 PM UTC
I’m specifically worried about losing my 1000 international calling minutes.
  • Nov 21, 2021 8:26 PM UTC
Hi @vtecman
Do you see a preview with the add ons that would stay before submitting the change?
  • Advocate
  • Nov 21, 2021 8:29 PM UTC
This is what I see. The original plan I’m on is behind it along with the new plan.  Nothing about add-ons.  And I feel like if I click this there won’t be an additional screen to confirm with add-ons.
Bernard Koodo
  • Nov 22, 2021 3:35 AM UTC
  • Advocate
  • Nov 22, 2021 3:43 AM UTC
It worked!  Thanks!
