How to enable VoLTE on Samsung Galaxy S20 FE 5g?
  • Dec 2, 2021 2:52 PM UTC
  • 15 replies
  • 2042 views
I can’t seem to get outgoing call display to work on my new Samsung Galaxy S20 FE 5g.  I had it enabled on my A8 (2018) and it says on the Koodo website that it work with this new phone.  Can someone tell me how to activate.
Best answer by rikkster
So, it looks like the VoLTE switch is working. Here’s how to enable outbound calling name display.
How can I add Outbound Calling Name Display to my account?
You can add the feature to your account by following these simple steps:
  1. Log in to Self Serve
  2. Select the Self Serve dropdown menu at the top
  3. Select Mobile services
  4. Select Manage add-ons
  5. Under add-Ons, locate Outbound Calling Name Display and select Add to plan
Heads up! It can take up to 24 hours for the account change to take effect.
Outbound Calling Name Display for mobile devices
Allan M
  • Dec 2, 2021 4:12 PM UTC
Are you trying to get call display or volte working? Or both?
  • Dec 2, 2021 4:14 PM UTC
To show your outgoing caller ID, tap the the Phone icon, then tap the options menu icon, (three dots in upper right corner of screen) and select Settings. Look for and tap Supplementary services - wait for the phone to stop ‘thinking’ and tap Show caller ID. By default, ‘Network default’ is selected and should display your number. If it doesn’t, select Show number.
To enable VoLTE, go to Settings > Connections > Mobile Networks - slide the toggle switch to the on position. On the same page, make sure the Network mode is set to LTE/WCDMA/GSM (auto connect).
  • Ambassador
  • Dec 2, 2021 4:21 PM UTC
I have the the show caller Id set to Newtwork Default. There is no place on the phone settings under Mobile Networks to turn on VoLTE. Do you know if this is needed to allow name and phone number display on outgoing calls?
  • Dec 2, 2021 4:39 PM UTC
It’s possible but with that setting caller ID should default to whatever network the phone is on.  Do you have the VoLTE access add-on in self-serve? There should be an option in Add-ons.
  • Ambassador
  • Dec 2, 2021 4:41 PM UTC
Hi Allan
I thought I needed VoLTE on in order to get my name to display on outgoing calls (along with my number).   What I really want is for the person I am calling to see my name and number.
  • Ambassador
  • Dec 2, 2021 4:43 PM UTC
Yes I have VoLTE access activated as an add on on my account.
  • Dec 2, 2021 5:05 PM UTC
Try this app. It worked to turn off VoLTE, it may work to turn it on. Similar situation where the VoLTE switch had disappeared for some reason. (Select the option More Network Settings).
Samsung Band Selection app
  • Dec 2, 2021 7:26 PM UTC
  • Ambassador
  • Dec 2, 2021 7:49 PM UTC
I do have VoLte add on on my account but I can’t make any changes to add on’s for 33 days because I changed my plan.  I assumed if VoLte was active that name display would work for outgoing calls but maybe they have changed something.
  • Dec 2, 2021 8:24 PM UTC
Interesting and good point. I would have thought that since you had outbound calling name display previously on your A8, the add-on would remain on your account. I’ve flagged a rep.
  • Ambassador
  • Dec 2, 2021 8:26 PM UTC
Thanks for your help.
  • Ambassador
  • Dec 2, 2021 8:42 PM UTC
I just checked my transaction history in my account and they cancelled outbound name display when I purchased my new phone. I wonder how I can go about getting re-instated?
  • Dec 2, 2021 8:44 PM UTC
Hi @Babs
The Outbound Calling Name Display is now added to your line, please try restarting the device and let us know here if it works.
  • Ambassador
  • Dec 2, 2021 8:45 PM UTC
Now on my add ons it appears it has been added on again. Not sure what is going on.
  • Ambassador
  • Dec 2, 2021 8:48 PM UTC
Thank you Flo. It is working now.
