How can I figure out if I will keep my perks?
  • Aug 15, 2023 9:56 PM UTC
  • 172 views
Recently, I switched from my previous plan to a reduced speed but 75 Gig plan. It included 2 perks (international minutes, which I had before and which are super important to me, but would cost another 10 bucks if I  lost them).
I am thinking of switching phones. The only one on Koodo’s website that I am half interested in (Why is the new Motorola Edge not available????) is the Samsung Galaxy 23 (although I am so done with this annoying Samsung A52).
At first every attempt that I made of buying a phone on Koodo’s website with tab resulted in a ‘you can’t keep your plan with this offer’ message. Now it says I can keep my plan, but ‘you can buy perks after purchase’ … To me that sounds like I will be loosing my perks, which I consider part of my plan.
(BTW the number of phones available has markedly decreased or am I seeing this wrong? Do they really want us to sign up with TELUS? Is that it?)
  • Aug 15, 2023 10:43 PM UTC
Telecoms mark up phone prices.  Can you purchase the phone you want direct fromthe manufacturer?  If you can, then i recommend that route and then you wont have to worry about any of this plan change stuff
Bernard Koodo
@Sang-gye Buschmann Did the issue happen even with Tab Basic? The rest of the tabs require higher plan eligibilities.
@Dennis
I don’t think you are correct.
When purchased on Tab the phone’s price is currently $620, whereas I don’t see it retailed anywhere below $799 (and that’s Walmart.ca … who knows if it actually available … have some bad experiences with their online market).
@Bernard Koodo
yes, that happened even with the highest tab (0 down, $24.93 for 24 months).
@Bernard Koodo …. I now see what you are saying … let me double check.
  • Aug 18, 2023 9:53 PM UTC
What I am saying is the the retail value on the samsung website is $1099 and on Koodo’s page, it retails for $1360.  Canadian carriers all inflate the retail price so that any sale price they give, also inflates the Tab bonus, resulting in a contract-like penalty if you want to upgrade early or leave koodo early.
