Europe - Easy Roam and Roaming
  • Jul 7, 2025 4:44 PM UTC
  • 2 replies
  • 499 views
Travelling to Europe, have easy roam… if we purchase a travel pass, are we charged for the $50 travel pass as well as the $16/day easy roam charges? Or does the $50 cost cover it all? Thank you!
Best answer by Flo Koodo
Hi ​@DDWPST
If you add the European Travel Pass, you won’t be charged Easy Roam $16 daily, while the travel pass is active, as long as you  are in one of the eligible countries, included in the travel pass.
In case you want to call or text numbers in a country other than Canada and the country you currently roam, then those will be charged pay per use, as they are not covered by the travel pass.
  • Jul 7, 2025 5:22 PM UTC
Hi ​@DDWPST
  • Jul 7, 2025 6:46 PM UTC
Thank you very much for the information!! Very much appreciated!
