Do I keep the Easy Roam with Canada-US plan?
  • Dec 16, 2024 3:51 PM UTC
  • 1 reply
  • 303 views
I just switched to the Canada- US plan. Do I keep the Easy Roam activated, or should I deactivate it? I don't want to get charged daily on Easy Roam, much cheaper to change the plan!
Thanks everyone!
Jen
Best answer by Oliver C
so if you have a CAN-US plan then you don’t necessarily need to keep Easy Roam. If you only travel to the USA and Canada, then you don’t need it as your plan will cover you. If you keep it and you only travel to those countries, you won’t get charged any extra fees.
The only reason you should keep Easy Roam is if you decide to go to another country other then Canada or the USA as you will need it to use your plan, of which you will get charged the roaming fees.
So in summary, you don’t have too, but if you travel elsewhere you may want to keep it in case you need it 🙂 more info can be found in the link below.
https://www.koodomobile.com/en/help/traveling-with-your-canada-us-rate-plan
1 reply
  • Dec 16, 2024 3:59 PM UTC
