Cannot add Perk after changing plan
  • April 1, 2026
  • 8 replies
  • 123 views
I recently changed my plan based on offerings from the flash sales that ended yesterday.  Previously I had 3 day international roam as my free perk.  Now my self serve has a notification to pick my perk, and it pre-selects 3 day international roam.  When I go to confirm, it now says “no perk selected”.
Best answer by Oliver C
there seems to be a system glitch lately that is making it that people cannot choose a perk. I will flag a rep for you to attempt to add the perk on their end.
They will respond here as I have just make sure you’re logged into the community using your self serve credentials. Note, response times can vary.
  • April 1, 2026
You’ll want to try clearing your browser cache and cookies for koodo.com. After that, log back into Self Serve using an incognito window and try adding the 3 day international roaming perk again. Make sure no existing perks like a conflicting travel pass for the same countries are still active because perks cannot stack if there is a destination overlap. You’ll want to wait 2 to 3 hours after a plan change for backend sync since flash sale changes can lag. If it still shows no perk selected, restart your phone to force a refresh. If you have no luck after 24 hours, finish the plan change without the perk first and add it later via koodo.com/chat or we can flag a rep for assitance here.
What have you tried so far?
  • April 1, 2026
  • April 1, 2026
Hi there ​@LBJD In order to confirm, do you want the same 3 Day Easy Roam International perk going onwards?
If so, do you want it on all the numbers on the account ? If you want it on only one of them, you can share the last 2 digits in order to identify the number. For your privacy and security, do not include the full phone number.
  • April 1, 2026
Hi, yes I would like the three day easy roam international as the ongoing perk for both lines in the account.
  • April 1, 2026
Got it ​@LBJD
We’ve attempted to add the $0 3-day Easy Roam International perk to your lines and we’re experiencing the same issue you mentioned. We’ve submitted a request to have our team add the perk on their end.
The perk should be provisioned to your account within 3 business days, thank you so much for your patience!
  • Member
  • April 6, 2026
Hello, After selecting the free perk, my profile does not get updated either. I have 3 lines and specifically want to add the 3-day Easy Roam International perk to all of them but would specifically like it on the line with last 2 digits 43 as I will be traveling in a couple of weeks
  • April 6, 2026
Hi ​@DJAB
I will flag a rep back to the post for you so that they can help you out.
As mentioned above, make sure to be logged into the community using your self serve credentials. 🙂
  • April 6, 2026
@DJAB
We have tried to add the perk from our end but it was not successful, however we have submitted a request and it should be added in the backend within 3 business days on all 3 lines.
Please let us know in case the perk is not added.
Thank you for your understanding!
