Cancelling or re-setting dates for Europe travel pass
  • July 12, 2026
  • 3 replies
  • 42 views
I purchased a 30-day Europe travel pass on July 9 for a trip that starts Aug 22.  Admittedly I jumped the gun a bit and probably should have waited until closer to the date I leave.  When I check my account, it says that the travel plan expires Aug 23 so I would like to either cancel the current travel plan or re-set the day that it starts.  How can I do that?
Best answer by Flo Koodo
Hi ​@Altagal
Do you see the option to remove it in serve under Mobile services - Manage add-ons?
  • July 12, 2026
Hi ​@Altagal
  • July 12, 2026
Yes, I do see that.  I’ll try that.  Thanks!
  • July 12, 2026
No problem, let us know if you are unable to remove it in self serve and we will help you out!
