Can/US Roaming vs Easy Roaming
  • Sep 7, 2025 2:54 PM UTC
  • 1 reply
  • 170 views
Im currently on a plan that says it includes Canada and US Roaming w/ data, talk, text.
I recently switched to this plan but I still seem to have Easy roaming enabled.
When I came to the US and turned on Roaming I got a text saying im going to be charged $14 a day for Easy roaming.
I dont understand how I can have both. Do I need to disable Easy Roam as to not be charged and use what is included on the plan?
Best answer by Flo Koodo
Hi ​@viaAndrea
With a Canada-US plan, you won’t be charged for roaming while in the US even though you have the Easy Roam add on.
There are howeve some exceptions, you can find them here https://www.koodomobile.com/en/help/traveling-with-your-canada-us-rate-plan
Let us know if you have further questions.
1 reply
  • Sep 7, 2025 3:09 PM UTC
Hi ​@viaAndrea
