Barbardos roaming
  • September 29, 2026
  • 64 views
Hello,
It seem that Koodo’s  Caribean destinations does not include Barbardos?  What will be the roaming solution for  Barbardos then?
From this link https://www.koodomobile.com/en/help/europe-easy-roam-travel-passes?srsltid=AU7gw4XHZol_4pofpZJO5BMdJOhvWwbIisoMJGn_1totn4Y01kgpboPT
The eligible Caribbean/Mexico destinations include:
  • Antigua & Barbuda
  • Aruba
  • Bahamas
  • Bermuda
  • Bonaire
  • British Virgin Islands
  • Cayman Islands
  • Curacao
  • Dominica (Commonwealth Of)
  • Dominican Republic
  • French Guiana
  • French West Indies
  • Grenada
  • Guadeloupe
  • Guyana
  • Jamaica
  • Martinique
  • Mexico
  • Montserrat
  • Saba
  • St Kitts & Nevis
  • St Lucia
  • St Vincent And The Grenadines
  • St. Barthelemy
  • St. Eustatius
  • St. Maarten
  • St. Martin
  • Trinidad And Tobago
  • Turks & Caicos Islands
Best answer by MilkyWay
That is correct. Since Barbados is not included in the Caribbean & Mexico Easy Roam Travel Pass, it will be charged at the usual rate of $18 per day. https://www.koodomobile.com/en/services/easyroam
Thank you!
By the way, both Bell and Rogers Caribbean travel pass does include Barbardos.  Hope Telus/Koodo will cover Barbardos soon
I suggest you submit this as an Idea.
In the past Koodo’s Asia travel pass did not include Japan, but I submitted it as an idea and they made it happen.
I also submitted this idea recently too about the durations of the travel passes
Hi Dennis
How to submit “idea”?
You can submit an idea here.  Just select Idea for your Topic type
https://community.koodomobile.com/topic/new
