Hello! Wondering if someone can help i bought the bundle amazon netflix and disney and while the others were easy to activate whenever i click on active my amazon prime nothing happens. And doest seem like i can speak to a person and the robot does not recognize my questions can someone help? I dont want to give up and cancel all lol thank u very much
amazon does not work on bundle
Best answer by Dinh
Hi
When the activate button does nothing, it's usually the page failing to load its data. Could you try the activation link on a different web browser, or a different device? Turning off the pop up blocker has helped some people as well.
Also, do you already have an Amazon Prime membership on your own Amazon account? If you do, Amazon has to handle it manually, so you would need to contact Amazon support to sort that out first, then go back to Self Serve to finish the linking. It's mentioned on the Stream+ help page https://www.koodomobile.com/en/help/stream-plus
Login to the community
or
