adding a us plan for 2 weeks
  • Mar 3, 2025 9:48 PM UTC
  • 2 replies
  • 497 views
I am going to the United States and would like to use my phone there but I’m not sure how to add a data plan so that i can text and call and use social media. Anyone know how to add to my data plan?
Best answer by Flo Koodo
Hi ​@Addi2819
If your plan includes data, you can use the data allotment from your plan in the US, however, the daily Easy Roam fees apply.
If you plan to travel to the US for a longer period, you may want to check the Travel Pass options or you can check in self serve using these steps if a Canada-US plan is available for you.
  • Mar 3, 2025 10:18 PM UTC
Hi ​@Addi2819
  • Mar 3, 2025 10:21 PM UTC
Are you on a prepaid or postpaid plan?
For prepaid plans, you can purchase add-on boosters for U.S. roaming data. You can click the following link for more details. https://www.koodomobile.com/en/prepaid-plans
Otherwise, you can purchase an Easy Roam Travel Pass to the U.S., which should give you 7 consecutive days of Easy Roam. https://www.koodomobile.com/en/help/europe-easy-roam-travel-passes
