2 Numbers same phone ; would like to move my second line ( esim2 ) to a BYOD device ; my other cellular phone.
  • Jul 17, 2026 10:16 PM UTC
  • 2 replies
  • 69 views
I have 2 lines on my Phone. The primary which receives hundreds of spoofed calls, and the secondary number ( esim2 ).
I have a free cellular phone hanging around. I would like to move the secondary esim2 number over to my android phone.
Is this possible? What steps are involved?
Are there any changes in costs moving ahead with said idea should it be possible?
Thank you.
Best answer by Dennis
Yes it is possible if the android phone is compatible with esim.
Please review and follow the instructions here
https://www.koodomobile.com/en/help/esim-and-esim-vouchers?srsltid=AfmBOoqEs85U7Vo0LsIskTzP4Kx_bZdGXp5UqYpYGSlVxxauV4IjRKz-
  • Jul 17, 2026 10:27 PM UTC
  • Jul 18, 2026 2:28 AM UTC
You would be moving that second line's eSIM off your current phone and onto the spare Android. It's treated as a device change, not a plan change, so the plan and its cost stay the same.
is the spare Android eSIM-capable and unlocked? If so, you can move the line in Self Serve under the eSIM/SIM management section, which sends a verification code to your email/sim — the Android eSIM guide walks you through it: https://www.koodomobile.com/en/help/esim-on-android
If that spare phone only takes a physical SIM, you'd move the line onto a physical SIM instead. And if the verification code won't come through or Self Serve blocks the change, a Koodo store can issue a SIM with your ID.
