$15.00 per month plan switch
  • Mar 30, 2022 10:04 PM UTC
  • 387 views
Do I have to cancel my membership and begin again as a "new" customer in order to switch to this plan? Seems silly I can't switch to it despite being with Koodo for 13 years.
Best answer by Sophia
If you are (referring to the $15 3G starter plan), then all you need to do is schedule a callback from the digital assistant to speak to a rep, they can switch you over.
  • Mar 30, 2022 11:16 PM UTC
Are you referring to the $15 3G starter plan with 100mins and Canada only texting?
Sophia
  • Mar 31, 2022 12:05 AM UTC
  • Mar 31, 2022 1:11 AM UTC
For the same price, you are probably better off switching to Public Mobile. They have a similar plan, but you get unlimited international text and picture messaging on Public Mobile. You will only get unlimited Canada-wide text messaging on Koodo. https://www.publicmobile.ca/en/on/plans/15for250MB-3Gspeed
  • Mar 31, 2022 3:43 AM UTC
Yes, I am currently paying $25 per month for the same exact plan so I wanted to know how to get the $15 per month plan without the rigamarole of canceling and restarting with Koodo as a "new" customer but I think another reply gave me a blueprint to make it work. Thank you!
  • Mar 31, 2022 3:44 AM UTC
If you are, then all you need to do is schedule a callback from the digital assistent to speak to a rep, they can switch you over.
I will try this. Thank you!
