When calling 1-800 OR 1-888 prefixes uaing Koodo, is there a charge?
  • Dec 16, 2024 9:58 PM UTC
  • 2 replies
  • 283 views
Best answer by Flo Koodo
Hi ​@Poonie
Calls made to toll free numbers starting with 800/866/877/888 will be free of charge if made from within Canada.
However since they'll still use the minutes on your plan, if you run out of minutes, you will be charged for additional airtime. This should no longer be the case as long as you are on an unlimited minutes Canada-wide plan.
  • Dec 16, 2024 10:22 PM UTC
Hi ​@Poonie
  • Dec 16, 2024 10:27 PM UTC
Thanks for the answer.
