Voicemail problems
  • Jan 4, 2023 6:02 PM UTC
  • 2 replies
  • 197 views
RBartinHalifax
When I call my voicemail I receive the usual announcement, but none of the number keys is responsive. If I press 1, nothing happens.  Same with the other number keys.  It goes through the basic voicemail announcement. Then the call fails.  Have tried setting up voicemail again, and am unable to.  Every way I try to get into voicemail has the same result.  Otherwise, my phone is acting fine, I can send and receive calls.
Best answer by rikkster
Have you recently switched from another carrier to Koodo?
I didn’t see this mentioned in your post, thought I’d ask.
Have you tried restarting your phone?
Sometimes this resolves glitchy network problems. If you’re still not having any luck, let us know.
  • Jan 4, 2023 6:24 PM UTC
RBartinHalifax
Tried the restart and it works -- simplest solutions are always the best!  Thanks
