voicemail number unavailable
  • Oct 16, 2021 7:30 PM UTC
  • 1221 views
When I hold down the “1” to access voicemail it says “voicemail number unavailable”. When I go into the voicemail settings to check it shows no voicemail number assigned, but you can’t click on anything to input a number.
any thoughts?
  • Oct 16, 2021 7:36 PM UTC
Did it work in the past? Are you a new customer or an existing one.
Also, you could try to reset network settings of the phone and see if the phone can automatically fix it for you.
  • Oct 16, 2021 7:59 PM UTC
any thoughts?
Whereabouts do you live? You should be able to input the voicemail access number according to your location.
  • Member
  • Oct 23, 2021 11:19 PM UTC
I have used the voicemail function for years, and it always just dialed in when I touched the voicemail icon, but suddenly I have this same problem -- I can enter the voicemail number, but it won’t automatically come up.  My husband’s phone (same account) doesn’t have this issue.
  • Oct 25, 2021 7:27 AM UTC
Does it work when you try dialing 1 on your phone to access your voicemail instead?
  • Member
  • Oct 25, 2021 11:12 AM UTC
I can access it by dialing my own number, but when i try to access it through dialing 1, i get to the setup menu and at the 'set voicemail number' it's greyed out.
Nezgar
  • Hero
  • Oct 25, 2021 6:20 PM UTC
Hi @crisco111 As a workaround, you can set any one of the local voicemail access numbers across canada in one of your other speed dials (ie “2”) and it should function the same:
https://community.koodomobile.com/articles%2Dby%2Dkoodo%2D232899/voicemail%2Daccess%2Dnumbers%2D7804676
