Unlimited Long Distance PERK. Philippines
  • Jan 1, 2024 9:10 PM UTC
  • 12 replies
  • 476 views
Hi,
Does this include both Landline and mobile?    Are there number or area codes that not included?
Best answer by Oliver C
As long as the phone number is in one of the 28 counties outlined in the long distance perk, landline or mobile should not matter. However, some combinations of numbers are still charged. If you go to the bottom of this article, it lists the numbers that would still be charged international rates and fees. https://www.koodomobile.com/en/help/koodos-pick-your-perk-plans I hope this helps!
  • Jan 1, 2024 9:19 PM UTC
  • Organizer
  • Jan 10, 2024 8:14 PM UTC
Got this addon and tried using it.
When Calling a Cell Number in the Philippines  +6391xxxxxxxx  the Caller ID number showing is not my number.  Is there a way to make my number show as some people I call does not answer random number because they think it might be a scam.
  • Jan 11, 2024 12:25 AM UTC
When you call locally, do people see your number correctly via caller id?
  • Organizer
  • Jan 11, 2024 12:33 AM UTC
Yes.  But when I all +6391xxxxxxxx its always a different number showing up.  Random numbers
  • Jan 11, 2024 12:35 AM UTC
Do they have your number saved?
So everytime they see a different number from you?  Do you have your caller ID blocked?
If they call you, and you call back, do they still see a random number?
  • Organizer
  • Jan 11, 2024 1:19 AM UTC
Tried calling a number of times and always a different number showing.   Calling Canada or USA. my number shows up
  • Jan 11, 2024 1:26 AM UTC
Does this happen all the time when calling various numbers in the Philippines or a specific number?
  • Organizer
  • Jan 24, 2024 1:46 AM UTC
Tried again.
Called a smart line in Manila,
Caller ID showed  (0964) 913 0791    which is not my Canadian number of 647-888-xxxx
  • Jan 24, 2024 3:04 PM UTC
Hi @rltan
Are you able to insert the sim card in a different phone and test to see if your number is displayed when calling to Philippines?
  • Organizer
  • Jan 24, 2024 3:14 PM UTC
No Didnt try not.  Not sure if it will matter.  tried again and another (09xxx) number showed and different from the last one.
Iphone 14 Pro MAX 17.2.1
  • Jan 24, 2024 4:29 PM UTC
That’s odd!
We recommend scheduling a call back, so a member from the technical support team can look into it further.
  • Organizer
  • Jan 25, 2024 7:18 PM UTC
Ok  fixed..   call Back support rep have to de-activate and re-activate my plan and addon.  that fixed the Caller ID issue.
