Unable to connect with Blink cameras
  • Mar 20, 2025 10:17 AM UTC
  • 3 replies
  • 208 views
I recently bought two Blink cameras to monitor an elderly relative. I can access the cameras on my phone while Iโ€™m at her location, but anywhere else I get a network failure message. Blink suggests it could be a security setting issue on my phone, or a data limit problem. ย Can anyone help? Thanks.ย
Best answer by Oliver C
So does it also work when you're on wifi somewhere else? As it may be that you need to give the blink camera app permission to use data in your phones settings. If you don't, it wont work unless you have wifi connectivity.
  • Mar 20, 2025 10:20 AM UTC
  • Mar 21, 2025 12:26 AM UTC
Oliver, you called it! It was a data permission thing. Thanks so much!
  • Mar 21, 2025 12:40 AM UTC
No problem ๐Ÿ˜Ž glad it worked out!
