To unlock a iPhone SE purchased in 2016. Self service doesn't work.
  • Dec 1, 2021 3:30 PM UTC
  • 7 replies
  • 153 views
Hi I would like to unlock my iPhone SE that I purchased from Koodo in 2016. In the FAQ, it says "From the Self Serve dropdown menu, select Mobile services". but under my Self Service, I cannot find that option.
  • Dec 1, 2021 3:55 PM UTC
I cannot add photos atm for some reason but once you login to self-serve, you can select the self-serve menu button after you log in. It should be the 5th option down out of 6 choices “mobile services” and then it's at the bottom of the list of options to unlock your phone.
maybe you can screen cap what you do see in the menu?
  • Dec 1, 2021 3:58 PM UTC
I have only two options under self-serve. see the image.
edit: removed screenshot; reason: showing acc#
  • Dec 1, 2021 4:01 PM UTC
Ah… yes that would be where you'd see 6 options vs those two. I'll flag a Rep to assist with seeing if there is an issue with your self-serve account as well as unlock if your self-serve cannot be quickly fixed.
  • Dec 1, 2021 4:03 PM UTC
thanks!
Allan M
  • Dec 1, 2021 4:10 PM UTC
Can you try this link and see if it takes you there?
https://koo.do/MyServices
Have you recently cancelled your line with Koodo or anything or do you have a fully active account?
  • Dec 1, 2021 4:17 PM UTC
that link leads me to a blank page.
Yes. I cancelled my line yesterday after 11 years with Koodo.
I still get the phone but it cannot work with new carrier.
  • Dec 1, 2021 4:21 PM UTC
Hi @WayneWayne
Please check out your inbox, we have sent you a PM. Thanks!
