Stream+ Telus Films and Series
  • May 28, 2024 11:10 PM UTC
  • 4 replies
  • 2678 views
I took advantage of the Stream+ bundle with Netflix, Prime, Disney Plus, Telus Films and Series. For some reason we cannot access Telus Films and Series. Has anyone else had this problem? How do you get access? I tried to activate it
  • May 28, 2024 11:49 PM UTC
try going through this link and following the prompts. They recently changed to Telus films and series from something else so it can be a little harder to find. I hope this helps 🙂👍
https://streamplus.telus.com/telus-login?returnUrl=%2F
Bernard Koodo
@Jupiter12345 Have you been able to follow @Oliver C advice above? I have the same package as you and am able to access TELUS Films.
  • Jul 15, 2024 1:33 AM UTC
I am still not able to access
Allan M
  • Jul 15, 2024 1:45 AM UTC
What error(s) are you getting?
