Slow speed
  • May 23, 2026
  • 8 replies
  • 70 views
not sure if this is related but I am experiencing slow speeds since a few days ago as well...the network seems to be having issues
  • May 23, 2026
Do you get the same connection speed when you insert your SIM card into another device? Have you asked your close friends and neighbours in the area that are currently using Telus or Bell to see if they are experiencing the same issue?
  • May 23, 2026
I am currently on eSim.
Unfortunately I do not have anyone to check with in the area.
  • May 23, 2026
Where are you located? Are you getting better speeds when you leave your area?
  • May 23, 2026
I am in the Mississauga area near Mavis and Britannia.
The speed kind of fluctuates and it is a bit better now.
  • May 23, 2026
It may be due to interference in your surroundings that can weaken your signal. I would suggest you to restart your phone or toggle on and off airplane mode.
If you still experience this issue, you can schedule a callback through Koodo Assist and speak with a rep. They will be able to direct you to the appropriate team. https://Koo.do/Chat
  • May 23, 2026
ok thanks!
  • May 24, 2026
As well, which phone model are you using? have you tried to reset network settings of the phone to see if that can help?
  • May 24, 2026
What phone are you using?
Are you on 5G or LTE?
