Rogers-to-Koodo transfer cancelled after accidentally deleting Rogers eSIM
  • September 24, 2026
  • 61 views
My Rogers-to-Koodo transfer was cancelled after I accidentally deleted my Rogers eSIM. Rogers has agreed to manually approve the transfer once Koodo sends a new request.
I can’t reach a Koodo agent, and a callback won’t work because calls to my number go straight to voicemail. Can someone help restart the transfer and arrange a working temporary line for the callback, or another way to speak with support?
Best answer by Dennis
Let me flag a rep for you
I can’t even access my Koodo account now. It keeps showing an error even though I’ve reset my password five times. I can’t get help through Koodo Assist either because it just keeps asking the same question over and over again.
I suggest contacting the porting team 1-844-232-7678 with to see if they are able to re-trigger your port.  Your Koodo line should be working prior to the port with a temp number to make and receive calls
Thank you! I did call this number, but it routes me to Koodo Assist, which is an AI chatbot, so I can’t get an answer there. The IVR says they can’t find a request to port my number. I can make calls, but I can’t receive calls or texts. What should I do?
Hi ​@pankajbc, we saw you were able to speak to our team and they could assist with the port. We’re here if you have any questions.
