roaming notification even though i did not leave Canada
  • September 24, 2026
  • 3 replies
  • 60 views
I am in Canada and have always been in Canada.  I keep getting roaming notification emails and cannot address the issue thru the Bot.  The method of turning off the roaming possibility that the Bot suggests (manually select Koodo as the cellular network) does not work as Koodo is not available on the list of available networks
i don't want to be charged for roaming on both of my phone accounts and need this issue addressed
Best answer by Dinh
Eh,
Are you living close to the US border? Your phone can latch onto an American tower without you going anywhere, and that triggers the roaming notification. That notification is a generic notice though, it doesn't mean you're actually being charged. Have you checked your usage in Self Serve? any actual Easy Roam charge would show up there.
If a charge does land on an issued bill, you can submit it through Ask us to review a charge in Self Serve, accidental roaming like this normally gets credited https://www.koodomobile.com/en/help/ask-us-to-review-a-charge-on-your-bill
Which phones are you using? Koodo not showing in the network list is odd, and the menus are different on iPhone vs Android. For now I would turn data roaming off in the phone settings on both lines. You wouldn't be able to select Koodo if your area didn't have Koodo signal
Eh,
if you see other networks including roaming networks, then it sounds like you are in an an area with no Koodo coverage and the best coverage seems to be with a roaming network,
In these cases, your choices will be to continue to roam on a foreign network and pay for roaming, switch to a Canada-US plan, or find a provider with better coverage in your area
  • September 25, 2026
There may be an issue with the cellular tower in your local area.
I would suggest you to schedule a callback through Koodo Assist to speak with a rep and let them know about the poor coverage. They should be able to relay the details to the technical service department. https://Koo.do/Chat
