RMX3301 Realme (GT2 Pro)
  • Sep 27, 2023 5:29 PM UTC
  • 4 replies
  • 228 views
I am interested in this phone, however I am unable to desipher the information on compatibility.
Is there anywhere I can find this information? Everything looks like it will work, but I’d like to be sure, prior
to purchasing it,
Best answer by Dinh
Your phone should be ok on 3G, LTE and 5G(if you had a 5G plan).
However, as I mentioned earlier, it isn’t compatible with VoLTE or VoWifi as of now. So you would have to depend on 3G for calling.
  • Sep 27, 2023 7:28 PM UTC
Here is the official compatibility information from Koodo https://www.koodomobile.com/en/help/my-phone-compatible-koodo
You could as well post your phone model and its network band here so someone can help.
Anyway, phones from other region wouldn't be compatible volte and vowifi from Koodo. Make sure you know about it before purchasing the phone.
  • Sep 27, 2023 9:33 PM UTC
The phone model was in the title, but it is a Realme RMX3301 (GT2 Pro).
This is just garbled information for me.
NETWORK Technology GSM / CDMA / HSPA / EVDO / LTE / 5G
2G bands GSM 850 / 900 / 1800 / 1900 - SIM 1 & SIM 2
  CDMA 800
3G bands HSDPA 800 / 850 / 900 / 1700(AWS) / 1900 / 2100
  CDMA2000 1xEV-DO
4G bands 1, 2, 3, 4, 5, 7, 8, 12, 13, 17, 18, 19, 20, 25, 26, 28, 66 - International
  1, 2, 3, 4, 5, 7, 8, 12, 13, 17, 18, 19, 20, 25, 26, 28, 34, 38, 39, 40, 41, 42, 66 - China, India
5G bands 1, 3, 5, 7, 8, 20, 28, 38, 40, 41, 66, 77, 78 SA/NSA
Speed HSPA, LTE-A, 5G
  • Sep 27, 2023 11:41 PM UTC
  • Sep 27, 2023 11:50 PM UTC
Thanks for the info, I appreciate it!
