Refer-A-Friend Max Limit
  • Mar 17, 2026 3:26 PM UTC
  • 1 reply
  • 99 views
The Koodo Refer-a-Friend terms (https://referafriend.koodomobile.com/common/terms) state:
  • There is no limit to the number of referral offers you can send to your friends. However, you're limited to a maximum of $150 off your bill per calendar year.
How can I tell from my referral status page on whether I have more available slots to refer more friends?
Best answer by MilkyWay
It says there is no limit, so you can send as many referrals as you want. There is only a cap on the amount you can get from the referrals.
1 reply
  • Mar 17, 2026 3:30 PM UTC
