Question About Stream+
  • Sep 12, 2024 5:53 PM UTC
  • 384 views
I recently came across the Stream+ bundle through Koodo, and I’m interested in subscribing. Currently, I have monthly subscriptions to Amazon Prime, Netflix (Standard with ads), and Disney+ (Standard with ads). If I subscribe to Stream+, what will happen to these existing charges? Is there anything I need to do to avoid being billed separately for these services as well as through Koodo?
Bernard Koodo
@Discovery24 On out Stream+ if you scroll down one of the top FAQs is your question. The answer is below:
There are additional topics if you need more help, but the sign up and linking of accounts is super easy. And on top you will save close to 40% as a Koodo customer. Hope this helps!
  • Member
  • Sep 12, 2024 6:33 PM UTC
Yes, I did read the fine print prior to posting. Do those rules apply if I have a monthly subscription (and not an annual one) with the three separate services?
Bernard Koodo
@Discovery24 Easier if you have a monthly subscription.  If it’s annual each content provider has different approaches for the suspension of the annual plan or refund as well.
In my case I had an Amazon Prime annual subscription. I signed up for Stream+, linked the Amazon account and subsequently asked them to refund the remaining months. It was easy.
  • Sep 12, 2024 7:49 PM UTC
To play it safe, I would cancel all 3 monthly accounts and then sign up with Stream+ once the 3 subscriptions stop working.
I know you dont need to do it this way, but it is cleaner and will prevent any preventable hiccups that may occur between the Koodo subscription and the 3rd party’s subscriptions.
  • Member
  • Sep 12, 2024 11:14 PM UTC
Good idea! Can I reactivate Amazon, Disney+ and Netflix using the same email, or would I have to use a different email to sign up for them via Stream+?
  • Sep 13, 2024 12:26 AM UTC
