Public Mobile offer
  • June 15, 2026
  • 111 views
Martin Couture
I’m a PM customer with 35$/100Gb CA-US-MX.
I’m being offer to switch to Koodo to 40$/150Gb CA-US-MX. with offer code ANYTIME-KOODO-WEBMIGRATIONS
Which type of TAB this plan will be giving me if I switch?
Best answer by Flo Koodo
Thank you for sharing ​@Martin Couture
The plan is eligible with the Happy Tab Lite.
  • June 15, 2026
Hi ​@Martin Couture
Did you get this offer by email or you are seeing it in your account?
Martin Couture
It’s in the app, then I’m being redirected to the Koodo website.
  • June 15, 2026
Martin Couture
Thank you ​@Flo Koodo
One last question: is there a limit on the roaming in Mexico? In Days, in Data, in Months? I want to see those fine prints!!!
  • June 15, 2026
No, there is no limit when it comes to how much roaming you can do with a Can-US-Mex plan within the applicable countries.
When roaming in USA or Mexico, you get all of your plan features for free which includes calling, texting, and the amount of data that comes with the plan (150GB). You can also call and text numbers between these countries and within them.
The only limitations that come with the plan is that WiFi calling only works in Canada, not all numbers are included when roaming in the USA, and you can only roam for free in locations that are considered a part of that country. More information can be found in the link. 🙂
Travelling with your Canada-US plan or Canada-US-Mexico plan | Koodo Mobile
