Outgoing call not working while roaming outside of Canada (easy roam)
  • Apr 14, 2022 4:32 AM UTC
  • 458 views
Outgoing call not working while roaming outside of Canada (easy roam).
I am India and easy roam activated.
receiving incoming calls and outgoing call is not working. Getting message saying outgoing call from this number is not allowed.
Best answer by MilkyWay
Yes
Have you tried manually selecting a network? You can look at this list to see which ones to choose from. Do you see any of these carriers showing up?
  • Apr 14, 2022 4:56 AM UTC
Did you include the International Voice Roaming add-on to your Self-Serve account?
  • Apr 14, 2022 10:51 AM UTC
Yes
  • Apr 14, 2022 11:41 AM UTC
Yes
  • Apr 14, 2022 3:18 PM UTC
Does sending and receiving text messages work?
Does cellular data work?
  • Member
  • Apr 14, 2022 7:23 PM UTC
Mine is also not working, stuck in the Netherlands and can’t send texts or phone calls! I restarted the phone, manually selected the carrier and still nothing!!
  • Apr 14, 2022 8:24 PM UTC
Make sure to manually add the free $0 Data and Voice roaming add-ons via self serve.
There could be a slight delay of 15min before the changes actually take affect and in some instances a restart will be required.
