Numer ported to Koodo but no calls or data working
  • Jun 11, 2024 1:53 PM UTC
  • 831 views
Hi, I followed all the steps for number porting but I did not receive the Koodo welcome message and unable to make any calls or use 4G data. I can only receive calls and send and receive text messages. what is the fix as its been more than 12 hours since I ported. I see my correct phone number in self serve account.
Best answer by Flo Koodo
Hi @demegracias
We have checked on our end and we can see the transfer was successful.
Can you please restart your phone and reset the network settings and let us know if you are still experiencing issues?
  • Jun 11, 2024 2:01 PM UTC
a couple of things to try:
  1. When you did the number port did you restart the phone? (Sounds silly but is a necessary step)
  2. You could try resetting your network settings
  3. try taking out the sim, reinserting it, and see if the issue is resolved.
if none of those work, I suggest you try the sim in another device to see if the issue persists. If it does then the sim may be defective and replacing it may fix the problem. If it doesn’t persist then it would just be a setting in the phone that’s messing it up. Try these and let me know how it works out 🙂👍
Hi @demegracias
  • Jun 11, 2024 4:04 PM UTC
Hi @demegracias
Thank you for your help. I had to set it as a secondary number and it's’ working now. previous carrier sim was an esim.  I will reset the network settings.
  • Jun 11, 2024 9:23 PM UTC
its Fixed now. Reset network settings and also eSim. thank you
  • Jun 11, 2024 9:24 PM UTC
Awesome 😎 glad it worked out!
