Not Receiving Calls on New Phone
  • August 18, 2026
  • 2 replies
  • 38 views
Purchased a Google Pixel 10 XL , upgraded from a Huawei that was just getting
older.   I can call out but I am not receiving calls 95% of the time and not always when I am in a different location.
Phone does not ring or register that there was an attempt to call.  Several
clients and family getting upset and worried when they can’t reach me.
I have tried all suggestions that Koodo site suggests and
unable to reach a human tech support.  Any suggestions would be
appreciated.
  • August 18, 2026
Hi ​@Deb V
Just to double check, did the issue start after you switched to the new phone?
Have you had the chance to test the sim card on a different phone (if possible)?
  • August 18, 2026
Assuming you are using a physical SIM card, have you tried inserting it into another device to see if you are experiencing the same issue? If so, you may need to get a replacement SIM card.
You can order it from the Telus website or your nearest Koodo store and update it on your Self-Serve account. https://www.koodomobile.com/en/help/koodo-sim-support
