No incoming calls or texts
  • Dec 1, 2021 9:47 PM UTC
  • 3 replies
  • 1067 views
Hi there!  The past couple of days I have not been able to receive calls or text messages to my Koodo line.  I can make calls, and send texts, and data works just fine.  I’ve been with Koodo over a year so no porting, and my billing is up to date.
I’ve reset my phone, reset the network settings, checked to ensure no forwarding/DND issues.  It literally just stopped working and I can’t figure out why.  I can’t take a call from support because I can’t receive calls and facebook support has been silent.
Does anyone have any ideas?
  • Dec 1, 2021 10:31 PM UTC
This is strange, was your phone set to “do not disturb mode”? or “silent” ? When someone called, what did they hear? Could they leave a voicemail for you? Also, which phone are you using? was there any block on incoming calls/text setup in the phone.
Anyway, do you have another phone or friend phone that you could put your Koodo SIM in it? if you have, I suggest you put the SIM in it, it would help to identify if the problem was from the phone or the SIM or Koodo network in the area.
  • Dec 3, 2021 6:51 AM UTC
Have you tried to contact them on Twitter as well? https://twitter.com/koodo
  • Dec 3, 2021 11:19 AM UTC
Which phone do you have?
Try switching the network mode from LTE to 4G or 3G to see if this restores incoming calls and texts. The link below mentions a similar problem.
Download Fongo Mobile (Android or iOS) to get a free Canadian phone number. Works over mobile data or Wi-FI. This will allow you to receive a callback.
Fongo Mobile
Koodo Assist
