New Phone - Same Plan
  • Dec 20, 2021 2:20 PM UTC
  • 727 views
I have a Samsung A5 that I purchased on Tab four years ago. The Tab balance is zero and I would like to get a new phone. I like the plan that I have now and do not want to change the plan. All the offers ask to change to Tab Plus or some other plan. How can I keep my current plan and get a new phone with Koodo?
Allan M
  • Dec 20, 2021 3:22 PM UTC
If the site isn't letting you keep your plan when you go to upgrade then chances are that plan isn't eligible for Tab plus.
What is the plan that you currently are on?
  • Dec 20, 2021 3:45 PM UTC
According to the plan you have, you might be eligible for some tabs. Unfortunately, the best plans are with different tabs in order for customers like you to change from their old plan.
  • Dec 21, 2021 12:33 AM UTC
Tab plan $50 a month is close but more expensive than my current plan. It offers more data but I never go over on data so not that important.
Mayumi
  • Dec 21, 2021 12:36 AM UTC
What phone are you located looking at?
  • Dec 21, 2021 4:07 AM UTC
In orde to get a phone on a particular tab your plan must be higher then that threshold. If not, you can get the phone on a lower tab but some deals might not be available on those.
  • Dec 21, 2021 4:51 PM UTC
