New account registration - call asking for PIN and DL
  • Nov 28, 2026 6:36 PM UTC
  • 4 replies
  • 28 views
Earlier today we registered for new Koodoo accounts for a deal with a new phone.
We received a call from what looked like Koodoo. They asked for our PIN and also a photo of our drivers license.
Is this legitimate? Quickly searching shows this may be valid, but also other things say Koodoo will never call and ask for a PIN or photo of documents.
I cannot schedule a callback through the assist tool, it keeps sending me here.
To add to that. They sent us both an email with a ref#. For my partner they had the correct order # referenced, though she did provide her PIN before stopping the call.
I did not pick up, and the email I got has the wrong order ID #.
  • Nov 28, 2026 6:58 PM UTC
Koodo does call new customers after an online order when they need to verify your info for the credit check. They try by phone over 3 days, then send an email saying they will try again in the next 24 hours. More info here https://www.koodomobile.com/en/help/credit-check-requirements
Since your email has the wrong order number though, I wouldn't send a photo of your licence or anything else until you confirm with Koodo directly. Go to Koodo Assist https://www.koodomobile.com/en/help?autobots=rollout and type #verifymyinfo, it should connect you to a rep instead of sending you here. They can tell you if the verification on both orders is real.
As well, since your partner gave her PIN, I recommend she change her Self Serve password right away.
  • Nov 28, 2026 7:06 PM UTC
Thanks, I sent them an email. Unfortunately when it asks about a callback, it sends me here again.
It's likely fine, but that incorrect order number certainly leaves me skeptical.
  • Nov 28, 2026 7:52 PM UTC
​@Uklamen
We have looked into it and we can see there was a voicemail left and an email sent from the webstore team today, according to the note on your account.
A verification is required for the order approval. If you emailed the webstore team, you should receive a response, however it may take a bit given the Black Friday period. As suggested by ​@Dinh, we recommend trying again later or tomorrow if you don’t hear back, to schedule call back.
  • Nov 28, 2026 8:37 PM UTC
Thank you for clarifying. When I speak on the phone I'll make sure they update the order number for me.
