My phone won't ring
  • August 14, 2026
  • 85 views
I have an iphone 17 pro and have a koodo month to month plan. All in good standing.
I pay for my mom’s phone too. She was complaining that she was missing a lot of calls.
The same has been happening to me. When I get a stranger to call my phone it is blank air for like 30 seconds and then call fails.
I have tried the following.
  1. check account is paid - it is
  2. reboot the phone
  3. turn off 5g
  4. turn off cellular, turn back on
  5. reset settings
Is there a webpage listing current koodo outages? This is enough to walk out the door to a competitor.
  • August 14, 2026
There's no public outage page for Koodo that I'm aware of, unfortunately. Is your mom on an iPhone as well? Two lines behaving the same way narrows things down a lot.
Two things I would check before anything else. Live Voicemail on iOS can interfere with Koodo voicemail, and that matches what you're describing, dead air on the caller's end and then a failed call. Try turning it off in the Phone settings. As well, make sure Focus/Do Not Disturb isn't on.
If nothing changes after doing so, you can put your SIM in another phone and see whether the problem follows the SIM or stays with the iPhone. More tips here https://www.koodomobile.com/en/help/im-not-getting-any-network-service
  • August 14, 2026
Thanks for this. I turned off live voicemail. Also, focus is off.
I just tried calling my phone repeatedly using my wife’s (Bell) phone. Still no response.
I have an esim. I do get 5g internet just fine.
Another thing I noticed. I call my wife’s phone and it takes a LONG TIME for her phone to ring. I just counted to 26 until her phone rang.
  • August 15, 2026
From your description, it seems your location doesn't have good signal reception. Have you tried to enable wifi calling?
How about other people living near you. Are the experiencing the same issue?
  • August 16, 2026
Hm. I was able to make calls with my wife’s phone. And data is fine. I am at home where the signal is good. Unfortunately this has been going on for a while. Even in downtown toronto. My phone takes forever to dial another number, too.
I’ll try a koodo kiosk.
  • August 17, 2026
It is possible there is some sort of interference in your home. Have you tried enabling wi-fi calling on your phone? That may help resolve the issue. https://www.koodomobile.com/en/help/wifi-calling
  • August 19, 2026
SOLUTION FOUND - VoLTE provisioning not configured during phone transfer
If you find yourself here, internet stranger, here is what I did to resolve the problem.
Tired of “have you turned your phone off” type of AI tech support, I used google gemini to paste in what my situation was. Gemini said this:
“When you got your new iPhone 17 Pro and activated the eSIM, your data plan was provisioned correctly, which is why your internet and WhatsApp calls work perfectly. However, the specific network code that allows regular phone calls to travel over the LTE/5G network (VoLTE) was likely dropped during the transfer.”
I called Telus. Not Koodo. Telus customer service at 1 833 896 0430 and said I had this problem for a month. Could they check the status of my VoLTE provisioning? Account blah blah blah.
This provisioning was not there. They added this provisioning. It is free. I turned the phone off and on. It works now.
So there, I tried everything. It was a bad new-phone activation. Sharing for anyone else it may help.
